Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Impala
Electrical
Fuse Panel
Location
OBD Fuse location needed?
2018 CHEVROLET IMPALA
85,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
SANFURDT
MEMBER
OBD scanner is not working. Which fuse does the OBD port use on my car listed above?
Aug 16, 2023 at 5:24 AM
Experienced Mechanic
It is the DLC 7.5-amp fuse in the interior fuse panel.
Here is a guide to help you check it:
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Aug 16, 2023 at 9:27 AM
SANFURDT
MEMBER
Thank you for the information. I found it and it was blown.
Aug 16, 2023 at 11:10 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Aug 17, 2023 at 3:48 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
