OBD code reader PO3O4-cylinder 4 misfire
162,000 MILES
COUGARPURRFECT
  • 7 POSTS
(1997 mercury cougar 4.6L) Service engine soon light went on recently(again) read the code with an OBD code reader I bought. What does this mean, im also wondering what price range I may be looking at to correct the problem (guesstimate). Curious cuz I need to know if I have enough saved up to deal with the problem. Thankz.
May 13, 2013 at 12:37 AM
CARADIODOC
  • 34,414 POSTS
That's one of the few codes that means just what it says. Cylinder four is misfiring at times. It could be as simple as a fouled spark plug or bad spark plug wire. The most serious cause would be compression-related like a burned valve or worn camshaft lobe. A fuel injector could be plugged too but that is not real common.
May 13, 2013 at 3:34 AM
COUGARPURRFECT
  • 7 POSTS
Thank you (timez a million) for the insight .....
May 13, 2013 at 4:58 AM
