Obd code p260f
85,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
JOHNLA
What can be done to figure out how to fix this problem
Feb 22, 2016 at 6:20 AM
  • 55,710 POSTS
This code is for the EVAP system monitoring. There is a correlation issue that can usually be solved by resting the computer, (clear codes)
Here is a guide to help you fix the problem
https://www.2carpros.com/articles/check-engine-light-clear-codes
Cheers, Ken
Jun 15, 2017 at 6:05 AM
