Obd code P0505
150,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
DILL-11
  • 126 POSTS
It said idle air valve bad . So do I have to replace the ECM to?
Apr 28, 2017 at 6:00 AM
HMAC300
  • 48,601 POSTS
before you make the repair pull the ECM cover off and if you see a burnt spot then it is fried and you need another which is rebuild able. however, they have to be programmed to your car for security and a mechanic has to do it. it is quite common on this car.
Apr 28, 2017 at 8:34 AM
