OBD code P0171, will not start
130,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
JDUNFORD2871
Truck cranks so I'm pretty sure the battery is strong. But it won't start. Seems like it's not getting fuel. It was running fine the night before and I went out in the morning and nothing.
Feb 6, 2020 at 4:59 AM
JOETECHPRO
  • 705 POSTS
Hey JDUNFORD2871,
OBD code P0171 points to fuel system too lean, this would point towards a fuel pressure problem.
If the engine is turning over slowly then trying to boost with jumper cables or a jump pack will rule out a low battery state of charge.
A quick test to attempt to see if the fuel pump has stopped working would be to tap the bottom of the fuel tank whilst someone is cranking the motor. Using a rubber/wooden mallet or something that will not dent the tank. This can sometimes shock the pump and get it going. You then know you have a fuel pump issue.
Let me know how this goes. The next step will be to check fuel pressure.
Do you have access to a gauge for this?
Regards, Joe
Feb 6, 2020 at 8:51 AM
  • 55,746 POSTS
Here is a guide to help you as well:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Feb 9, 2020 at 2:46 AM
