OBD saying linking error
97,000 MILES • 2.0L • TURBO • 2WD • MANUAL
ANDREWBRESLIN
hi, i have tried a lot of models of OBD's on my car and on trying to find a code i press load and it comes up every time saying linking error. i can't seem to find out why all the other OBD scanners work on my mates and lasses car. so do not think it's the actual scanner problem.
Jun 17, 2020 at 9:00 PM
  • 110,248 POSTS
This vehicle isn't offered in the US, but I will try to help. As far as connecting, when you hook up the scan tool, does it turn on? Now, in the US, pin 16 always has 12v power. I would imagine it is a standard anywhere. Can you check to see if that is the case for you? Also, pin 4 should be the chassis ground. Check that for continuity to ground.
Let me know what you find.
Jun 18, 2020 at 12:14 PM
