obd 1 says throttle position sensor
45,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
XCRIDER76
  • 5 POSTS
I cant locate the tps I'm going crazy. I know where its suppose to be but I can not find it. Please help.
Sep 9, 2016 at 12:24 PM
SATURNTECH9
  • 30,868 POSTS
Do you have a carb or fuel injection?
Sep 9, 2016 at 11:37 PM
XCRIDER76
  • 5 POSTS
Carb
Sep 9, 2016 at 11:55 PM
SATURNTECH9
  • 30,868 POSTS
There's a picture of it.
Sep 10, 2016 at 12:06 AM
XCRIDER76
  • 5 POSTS
In that picture the one thats $21.79 is the one that shows fits my vehicle. Also i cant find it on the engine anywhere. I've researched all over and cant find pic of my car and same shape engine with it showing where tps is
Sep 10, 2016 at 12:25 AM
SATURNTECH9
  • 30,868 POSTS
That's the one that fits the one with a carb.Maybe it's missing?Have you had the car long?
Sep 10, 2016 at 1:23 AM
XCRIDER76
  • 5 POSTS
No about 2 weeks. Bought for $500 from this guy. Wasnt running so i changed battery,egr valve, fuel pump, spark plugs and boots. O2 sensor and fuel filter. Was running good for two days but at idle dies. When at light or to park. Obd1 says tps
Sep 10, 2016 at 4:34 AM
XCRIDER76
  • 5 POSTS
I wouldn't doubt its missing. Im missing vacuum hoses too, to the egr valve and air cleaner hoses also. Weird.
Sep 10, 2016 at 4:36 AM
SATURNTECH9
  • 30,868 POSTS
Your goingvto have to sort all that stuff out.Someone probably removed the sensor and never put it back.Missing vacuum hoses can cause vacuum leaks and idle issues.
Sep 10, 2016 at 9:48 AM
