OB2 scanner will not communicate
90,000 MILES • 4 CYL • 2WD • MANUAL
STEVEN424
Scanner will not communicate.
Feb 26, 2018 at 10:30 PM
STEVE W.
  • 15,370 POSTS
Use a meter or test light to be sure you have battery voltage on pin 16 and ground at pins 4 and 5. If no power check the DLC fuse in the under hood fuse block. If you have power and ground then try a different scan tool or try the one you have on a different vehicle to verify it works. What is the issue you are trying to scan for?
Feb 27, 2018 at 2:31 AM
STEVEN424
Thanks. scan is for light no real problems as far as drive issues.
Feb 27, 2018 at 2:35 AM
  • 55,554 POSTS
Good to hear did you get the scanner to work? also, please try the scanner on a different car to confirm it works.
Cheers, Ken
Mar 2, 2018 at 3:22 AM
