OB1/OB2
1994 TOYOTA
75,000 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
BLAKE-T
I have a Hiace 3L turbo.
I am trying to find the position of the OBD socket and what type of OBD it is to allow me to use a scanner/code reader.
May 14, 2017 at 12:39 AM
HMAC300
  • 48,601 POSTS
yours is an obd1 system. we do not have your model in US so i am giving you where location is on a Camry you must do E1-T1 to activate mil light on dash and count flashes for code it will be a two digit code. However, we may not have that code here as yours is a turbo.
May 14, 2017 at 1:45 AM
BLAKE-T
Thank you for your reply, I have been searching further and found the OBD1 socket, I then went on the web and found a site called-codes. rennacs, they have a diagram of my OBD1 socket and they call it-connector eighteen year range-1990 to 2000. Will your instructions for linking out pins-E1-T1 still apply for getting the codes?
May 14, 2017 at 1:58 AM
HMAC300
  • 48,601 POSTS
like I said at model was not and is not sold in US so I gave you one from a Camry it should be the same if not the light will not flash.
May 14, 2017 at 5:42 AM
BLAKE-T
Thank you for your help.
Regards,
Blake
May 14, 2017 at 6:54 AM
  • 55,694 POSTS
Here is a link that will help
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Please let us know what you find ;)
Cheers, Ken
May 16, 2017 at 7:38 AM
