This grey wire is the power feed for the oxygen sensor heaters, and the 2nd diagram shows where the power originates from, but you would be missing power for a bunch of other actuators as you can see if it was a fuse issue. So it sounds like there is a break in the Grey wire somewhere in between the sensor and the smart junction box behind the passenger side kick panel.
Images (Click to enlarge)
Sep 9, 2025 at 10:17 AM
