O2 sensor replacement procedure needed?
97,640 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
VLADSC50
  • 42 POSTS
Hi there, I need help with how to take off the bank 2 sensor 2 O2 sensor underneath the car. Also, how can I test the zO2 sensor before I replace it?
Jan 12, 2025 at 10:25 PM
  • 110,248 POSTS
The easiest way to test it is while it is still in the vehicle. Using a live data scan tool, you can watch how it reacts while the engine is running. The voltage should be between 0 and 1.0 mv. If you hit the throttle hard, you should see it react.
Also, take a look through this link for testing. It should help.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Here is a link that explains how to replace it:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
I attached a picture below showing its location. Let me know if this helps or if you have other questions.
joe
See pic below.
Jan 13, 2025 at 9:51 AM
VLADSC50
  • 42 POSTS
Hi Joe, thank you for the response. I went to take a look at the sensor, but one thing is missing, what do I need to take off to get to it? Do you have a step-by-step procedure from the manufacturer on how to take it off?
Jan 13, 2025 at 10:00 AM
  • 55,746 POSTS
You can go over this guide:
The size is 7/8 so you can clip the wires off and use a deep well socket, I would spray wd40 and let is sit for a few hours. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Jan 16, 2025 at 12:47 AM
