O2 sensor problem (check engine light)
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DSAENZ4
My check engine light will not turn off, i believe it is P0037. started off with a simple changing of the o2 sensors, then the catalytic converter, then the sensors again, then the harness, then the PCM. only thing that has happened from all those repairs was the light turns off randomly for at most three days at a time. Is there a fix that we have overlooked?
Jan 26, 2017 at 12:49 AM
HMAC300
  • 48,601 POSTS
scan for codes first so we know where to check. check fuses under hood as some have fuses for O2 sensors. then check fuel pressure with a gauge auto parts rent it may be low causing a lean condition. See link.
Jan 26, 2017 at 1:40 AM
