Where are the O2 sensors located?
272,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
APRILDOTY0401
Help! Need to replace O2 sensors for bank1 sensor1 and bank1 sensor2. Needing locations and to know part numbers if needed? Please and thank you for all ya'll do!
Feb 18, 2023 at 8:24 AM
  • 110,246 POSTS
Bank 1 on the engine is on the driver's side of the vehicle. If you look below, I highlighted where bank 1 sensor 1, and sensor 2 are located.
Pic two shows the manufacturer's part numbers.
Here is a link that you may find helpful:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Also, here is a link that explains how to check an O2 sensor:
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Feb 18, 2023 at 2:10 PM
