O2 sensor bank 1 sensor 1 wiring diagram needed?
215,000 MILES • 2.9L • 4 CYL • 2WD • AUTOMATIC
STARRPAT76
  • 6 POSTS
Have replaced sensor 3 times getting a sensor inactive code best I can tell only getting 0.47 volts to sensor can't find out what voltage is supposed to be coming to sensor. if I could find the correct wiring diagram it would help. Any tips on fixing this problem would be appreciated. thank you
Jan 8, 2025 at 12:28 AM
  • 55,694 POSTS
The heater circuit for the O2 sensor receives 12V from a fused power source and a ground signal from the PCM. The sensor generates its own voltage (between 0.1V to 0.9V) based on the oxygen levels in the exhaust. Here are the wiring diagrams and a guide to help you test the continuity from the sensor to the PCM.
Check out the images (below). Let us know how it goes.
Jan 9, 2025 at 3:35 AM
STARRPAT76
  • 6 POSTS
Yes I believe it's going to be helpful, but our weather has been bad here an haven't been able to try it.
Jan 12, 2025 at 7:31 AM
  • 55,694 POSTS
Oh ya, that is common, please let me know when the weather lets up and you can check it :)
Jan 13, 2025 at 5:07 AM
STARRPAT76
  • 6 POSTS
I pulled the trouble codes today I've got p2a00, p0134, and this is a new one p0053 it seems that every time I pull the codes there's always one new one.
Jan 13, 2025 at 6:12 AM
  • 55,694 POSTS
Yep, I would check the wiring to the PCM and if okay it sounds like the PCM is bad.
P0053 - HO2S Heater Resistance Bank 1 Sensor 1
P2A00 - O2 Sensor Circuit Performance Bank 1 Sensor 1
P0134 - O2 Sensor Circuit No Activity Detected Bank 1 Sensor 1
If the wiring is okay here is how to change the PCM out, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Jan 14, 2025 at 2:06 AM
STARRPAT76
  • 6 POSTS
I've checked wiring to o2 sensor no brakes. I'm getting 12volts on heater circuit i've got 9.3 resistance on o2 sensors heater I cleaned contacts on PCM but still getting trouble codes.
Jan 28, 2025 at 9:52 PM
  • 55,694 POSTS
I would send the PCM for testing, it sounds like it is bad.
Jan 29, 2025 at 12:43 AM
STARRPAT76
  • 6 POSTS
Where can I take it to or send it to ?
Jan 29, 2025 at 1:00 PM
  • 55,694 POSTS
I would search google or ebay.
Jan 30, 2025 at 4:00 AM
STARRPAT76
  • 6 POSTS
I still haven't got my truck fixed. I have been able to work on lately will let you know what the problem is when I figure it out. thank you for your help.
Feb 26, 2025 at 4:41 AM
  • 55,694 POSTS
No problem, have a nice weekend!
Feb 27, 2025 at 2:33 AM
