Oxygen sensor location and replacement instructions needed
68,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
LUISG5210
  • 9 POSTS
Where is the o2 sensor bank 1 located on my car?
Nov 17, 2016 at 8:09 AM
JIS001
  • 3,412 POSTS
On the exhaust manifold. See picture below. The one in the exhaust manifold will be bank 1 sensor 1, behind the catalytic converter is bank 1 sensor 2 on the image. Here is a guide to help you change the sensor out step by step with diagrams below to show you on your car
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Nov 17, 2016 at 8:23 AM
MAW0118
need to know how many O2 sensors are in the car listed above and where bank 1 sensor 2 is located exactly? I'm being told there are three, one 1 before and after the catalytic converter and also one inside the catalytic converter.
May 8, 2021 at 6:21 AM (Merged)
  • 110,248 POSTS
Welcome to 2CarPros.
Banks 1 and 2 refer to either a V6 or V8 engine. You have an inline 4 cylinder. There are two sensors. As far as the sensors, one is mounted after the catalytic converter and one is mounted on the exhaust manifold.
There isn't one in the catalytic converter.
I attached a picture. Numbers 2 and 3 show the locations of the sensors. Number 2 is the heated O2 sensor which is referred to as number 1 and number 3 in the pic is the heated o2 sensor after the converter. I also attached a second picture and highlighted where the sensor is before the converter. Note that it is at the end of the exhaust manifold right where it would enter the converter.
MAW0118
Thank you very much I believe I understand but to be clear sensor 2 is after the catalytic converter and I have looked down behind the engine (above the spark plugs) and seen an O2 hanging out.. now am I correct by saying that's before catalytic converter and I have to go right under that box "catalytic converter" and there should be another O2 hanging out?
also the reason I said there where three O2 sensors is I went to AutoZone and priced the sensors and they came up with three different sensors (upstream, center stream, and down stream) so I was very concerned.
  • 110,248 POSTS
Welcome back:
There shouldn't be one above the spark plugs. Can you take a picture of what you are seeing and upload it for me?
The one after the catalytic converter is actually in the intermediate pipe. If you look that the converter, you will see where it flanges and bolts to the intermediate pipe. At the beginning of the intermediate.
In the first picture above, sensor 1 is shows or identified with a number 2. The one after the converter is sensor 2.
I attached two pics. In the first one, I circled the two sensors and identified which is sensor 1 and which is 2. In the second pic, I copied and pasted from the removal and replacement page. You will see that it only indicates two.
I have to be honest, I have seen sensors in the converter, but not this vehicle. However, as soon as I say it, I'll be wrong. LOL If I am, the manual is wrong, too. LOL
Please feel free to let me know if I can help.
JAVIER VEGA
Car listed above is an LT. I changed the catalytic converter. The original one did not have a sensor connection and the one I installed does have a sensor connection. How can I make them work?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.]
I suppose you could go to a muffler/exhaust shop and have them weld in a pipe plug.Assuming you do not need 02 sensors for smog reasons.Hope this helps and thanks for using 2CarPros.
Danny-
SWITCH68
I need to change the bank 1 sensor 1 oxygen sensor can you help me? Please help Thank you
May 8, 2021 at 6:22 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. This is a tutorial for you to view showing oxygen sensor replacement:
I've attached picture steps below showing oxygen sensor replacement and location for your car. Hope this helps and thanks for using 2CarPros.
TOOLROX_923
Would someone be able to pinpoint exactly what i need for my car listed above LS model with a direct link to advance auto please? Thanks!
I'm trying to figure out what i need to get as well as where i might be able to locate it on the engine. Thanks!
Good morning,
I attached a picture of the location of the sensor for and a direct link with the part required from advanced auto.
It is at the back by the firewall in the exhaust manifold. It is a very tight fit.
I would also ask for the socket for removing it as well when you go for the part.
Why are you replacing it?
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
https://shop.advanceautoparts.com/p/acdelco-heated-oxygen-sensor-213-802/15730346-P?searchTerm=oxygen+sensor
TOOLROX_923
my check engine light came on the other day, so i took it to Advance to read the code and it is P0131 and it says it's the "Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 DTC Severity 2 of 3: Repair immediately if drivability issues are present. Threat to essential system components if not repaired as soon as possible."
So i called this garage where i took it for another issues a few months back to inquire with them, and they said it's a fairly simple fix and that i could do it myself if i wanted, i just need to locate where cylinder 1 is at so that i can identify bank 1 sensor 1....i know nothing about car repairs so even though it may be a simple fix for some people, i am completely stupid about vehicles just like there are many people who know nothing about how to operate a computer...lol. Thanks for all of your help!
You are welcome.
always glad to help.
10POINTBOB
  • 56 POSTS
how many o2 sensors are on my car listed above?
Good evening,
You have 2 sensors. One on the down pipe at the firewall wall side of the motor and one under the car behind the converter.
I attached location below.
10POINTBOB
  • 56 POSTS
Thank you Sir. Very helpful.
You are welcome.
Always glad to help.
THEBOSS
  • 31 POSTS
I had code p0141 checked fuses changed bank # 2 sensor.Drove car for 2 days cel back on same code po141 please help with what to do next. Thanks-Jerry-
May 8, 2021 at 6:23 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
You should check the supply voltages to all of the oxygen sensors with a meter to ensure they are getting correct power. If one or all of them are without power (or too much), trace wiring and test for shorts/opens in the wiring.
Possible causes of the code are below:
A code P0141 may mean that one or more of the following has happened:
-Open or short to ground in the wiring harness
-O2 heater circuit wiring high resistance
-O2 heater element resistance is high
-Internal short or open in the heater element
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions:
-Replace oxygen sensor(s)
-Repair short or open or high resistance in wiring harness or harness connectors
Hope this helps..
Thanks for using 2carpros.com!
THEBOSS
  • 31 POSTS
Thank you for the reply,I had to replace both sensors and the cel is staying off. I do appreciate the information you supply to many of us.Thanks again-Jerry-
JUNIIR PALACIO PEREZ
  • 9 POSTS
Trying to find the sensor inside the exhaust manifold/crossover specific to the Sfi 3100 V6 and also the wiring to the sensors.
Good afternoon,
I attached pictures of the location for the upstream and downstream O2 sensors.
What is the issue?
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
I attached the wiring for the O2 sensors. The brown wire is battery voltage for the heaters on each one.
  • 9 POSTS
I apparently have a third o2 sensor that I cannot find.
No, there is not.
There are only 2 sensors.
Why do you think there is a third sensor?
  • 9 POSTS
Crossover/ intake manifold?
No, there s no sensor there. That cross over pipe connects the front bank to the rear bank.
  • 9 POSTS
Okay, because I was at AutoZone and they have 3 different kind of sensor for my vehicle and i feel i might have got the wrong one. I can send images of these 3.
Please send me the images.
I attached the pictures of the correct sensors for your car.
This is from rockauto.
TANDERSON23
My 98 chevy Malibu with a V6 engine or 3.1 with about 106000+ Miles on It . How Many O2 Sensors does it have?
May 8, 2021 at 6:24 AM (Merged)
FAIRRACING31
  • 150 POSTS
Your vehicle has two 02 sensors. One upstrem and one dowmstream.
The upstream 02 sensor is mounted in the exhaust system before the catalytic converter. The downstream is mounted in the exhaust after the catalytic converter.
PAUL K.
On a 1998 Malibu 2.4L 4cyl., to which sensor does a P0141 OBD code refer ? If it's not the one after the catalytic converter, where is it located ?
Jun 8, 2021 at 3:40 AM (Merged)
  • 75,988 POSTS
This means the sensor behind the catalytic converter as bad here is a guide to help you do the job and the location below for your car.
Cheers
