Engine light turned on, code reader said o2 sensor
180,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RAVEN1936
Engine light came on so I attached my code reader to truck it produced codes saying the bank 1 o2 sensor 1 and bank 2 o2 sensor 1 were not functioning. replaced both sensors and cleared codes after forty five minutes running the light came back on and produced the same codes.
Mar 1, 2019 at 7:24 PM
Good morning,
What were the exact codes?
Rarely does a code identify a bad part, just failed systems.
Mar 1, 2019 at 8:41 PM
RAVEN1936
Have also check fuse that's related to o2 sensor.
Mar 2, 2019 at 1:18 PM
Got it. I need the code number.
Mar 2, 2019 at 1:56 PM
RAVEN1936
Codes are in the pictures attached.
Mar 2, 2019 at 9:53 PM
Sorry, no pictures attached. Can you repost?
Mar 3, 2019 at 12:48 AM
RAVEN1936
Po155, po154, po135 and po134.
Mar 3, 2019 at 2:44 AM
Got it.
I attached two wiring diagrams for you to view for the O2 sensors.
Check the listed fuses for power on both sides.
Mar 3, 2019 at 2:56 AM
