Check engine light is on, possible O2 sensor issue
2,345,789 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
GIZMO3559
I have the car listed above DC. my check engine light on, when test for the codes it's said the o2 sensor for heater. I change the one under the hood, but when I went to change the one under the car. I couldn't find it. There is no catalytic converter. What do I do to turn the check engine light off?
Apr 26, 2020 at 8:14 PM
Good morning,
Sounds like someone removed the catalytic converter and there should be an O2 sensor at the catalytic converter. If there is no sensor, then there is a wire connector there for hooking one up. That would be the reason for the check engine light because it sees an open circuit for the downstream O2 sensor.
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
I attached a picture of where the connector is located and where the sensor should be.
I would install the converter as it should be there by federal law and then hook up the sensor.
Apr 26, 2020 at 8:47 PM
