p0133 Oxygen Sensor Circuit Slow Response?
247,000 MILES • 1.8L • MANUAL
YAZIDAN
  • 141 POSTS
p0133 Oxygen Sensor Circuit Slow Response. What can cause this code? also can I clean the o2 sensor if so, what can I use to clean it? carb cleaner, brake cleaner? soak it in gasoline? ....etc.
Thank you for your help
Jun 22, 2026 at 11:57 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the known exhaust leak assessed and repaired, then recheck the code and sensor behavior under the conditions recorded in the freeze-frame data. If the fault remains, evaluate the sensor, heater circuit and mixture-control data using the matching diagnostic procedure. The reported resistance and airflow values are observations, not pass/fail specifications. Do not treat a cleaning attempt as a substitute for diagnosis.
Guidance references and applicability
Source discussion: question 1712904 https://2carpros.com/questions/o2-sensor-44882243--1712904 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted. HELLA: Lambda-sensor diagnosis https://www.hella.com/techworld/uk/technical/sensors-and-actuators/test-lambda-sensor/ General oxygen-sensor diagnostic background. Sensor type and vehicle-specific conditions must be established before applying test limits.
Read the replies · Discussion summary and reported outcome
  • 55,686 POSTS
At 247,000 miles, the most common cause is a worn or contaminated upstream sensor. But, it can also be an exhaust leak a bad/dirty MAF sensor. Do not try to clean the 02 sensor if anything checks out, I would get a new one.
Jun 23, 2026 at 6:41 PM
YAZIDAN
  • 141 POSTS
what I noticed is that the o2 sensor is slow only at idle very slow sometimes it stays lean for long time. the speed when the code was set was 0 mph ( I saw it on the freeze frame data) when driving on freeway it switches very fast. also, I noticed that the MAF sensor at idle is 1.35g/s. when I do a WOT while driving the o2 sensor read rich but the maximum load that I got is 70%. today I checked the resistance of the heather element of the o2 sensor. it was 9.2ohm. the MAF sensor is clean. about exhaust leak there is an exhaust leak but is after the upstream o2 sensor but not far away from it.it is where the exhaust manifold connects to the cat at the donut gasket. I don't know if it affects the o2 sensor or not
Jun 23, 2026 at 7:34 PM
  • 55,686 POSTS
Yes, the exhaust leak can effect the reading at idle. I would fix that first. What happens is the "pulse of the exhaust system can suck oxygen in up into the sensor messing with the readings, at faster RPM speed this will not happen. Let me know what happens after you fix it.
Jun 24, 2026 at 8:13 AM
Discussion summary
The owner reported P0133 and an oxygen-sensor signal that responded slowly at idle but switched more quickly during driving. An exhaust leak near the manifold-to-converter connection was also reported. The contributor suggested repairing that leak before deciding whether the sensor needed replacement.
Reported outcome: No leak-repair result or confirmed sensor failure was reported.
The sensor type, test conditions and vehicle-specific limits were not established. The thread does not prove that the leak alone caused P0133.
Read the original discussion
