Codes p0036, p0054, and p0056, O2 sensor 2 heater DTC?
250,000 MILES • V8 • 4WD • AUTOMATIC
KHALIDDVD
  • 56 POSTS
Bad acceleration response combined with poor mileage. Dtc set p0036, p0054, p0056..etc.
Jul 1, 2024 at 12:30 PM
  • 55,845 POSTS
These are all oxygen sensor heater codes.
P0036: Heated Oxygen Sensor (HO2S) Heater Control Circuit (Bank 1 Sensor 2)
P0054: Heated Oxygen Sensor (HO2S) Heater Resistance (Bank 1 Sensor 2)
P0056: Heated Oxygen Sensor (HO2S) Heater Control Circuit (Bank 2 Sensor 2)
Did all of these codes come up at once? If not let's replace the 4 oxygen sensors with new units, here are the locations in the images below, here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Clear the codes once the repairs have been completed and the problem should be solved. Check out the images (below). Let us know how it goes.
Jul 2, 2024 at 3:11 AM
