Good morning,
I attached 2 pictures for you of the location of the sensors.
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
They are torqued to 18-foot pounds of torque.
The front sensor is on the exhaust manifold. The rear sensor is downstream of the converter.
You need a 19 mm O2 sensor socket for the removal.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Do not go cheap on the sensors. Aftermarket cheap sensors do not respond well. Try to keep to the original equipment sensors.
Images (Click to enlarge)
Jun 15, 2021 at 8:26 PM
