Overdrive light flashing and low range light on
154,637 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ALEX ESGATE
  • 39 POSTS
o/d light and low range light came on started to shift funny. changed fluid and filter no change. replaced VSS sensor and speed sensor still light flashing and long shifts. anything else i could try?
Mar 21, 2022 at 4:20 PM
  • 110,248 POSTS
If you replaced the sensor and there is no change, before spending any more money, have the can-bus scanned for codes. CAN stands for controller area network. Basically, all the different computers/modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link showing how it is done:
Let me know if this is something you can have done. I can understand the shifting issue if the OD light is flashing, but the 4lo is interesting.
Mar 22, 2022 at 2:16 PM
ALEX ESGATE
  • 39 POSTS
okay, i will get it scanned i have shifted the 4 wheel drive selector in and out and can hear it going in and out so do believe it is in 4 low just figured it may indicate what issue is .
Mar 22, 2022 at 9:35 PM
  • 110,248 POSTS
If it is in 4low, the vehicle's top speed will be around 30 MPH. Is that what you are experiencing?
Mar 23, 2022 at 9:27 AM
ALEX ESGATE
  • 39 POSTS
no i am sure it's not in 4 wheel at all.
Mar 23, 2022 at 2:34 PM
  • 110,248 POSTS
Okay. Let me know if you find anything when having it scanned.
I will watch for your reply.
Mar 24, 2022 at 11:59 AM
