Overdrive flashing light
120,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
LEDGEE17
Hi, I am wondering if you can help me. The car drives fine for ten minutes then a sudden shunt and overdrive light starts flashing and car goes into limp mode. Thank you. Gary
Jun 18, 2018 at 4:48 AM
KHLOW2008
  • 41,812 POSTS
Hi Gary,
When the overdrive light flashes, it means the transmission control module has detected a fault within the system and goes into limp mode. You need to retrieve the trouble codes to understand what is wrong to continue with diagnostics and rectification.
Most parts stores provides scaning services. Get one done and let us know what the codes are and we shall continue from there.
Jun 19, 2018 at 12:36 AM
LEDGEE17
Thank you for the quick reply I will do as you said tomorrow and get back to you. Thanks again.
Jun 20, 2018 at 7:08 AM
