Nut size for wheel hub needed?
100,000 MILES • V6 • 2WD • AUTOMATIC
KENNY WAGGONER
Need to know what size socket I need to take off wheel hub.
Apr 19, 2023 at 2:17 PM
  • 110,246 POSTS
Unfortunately, the manual doesn't provide the size. However, if this is a 2wd, you should be able to remove it with something like a crescent wrench or channel lock pliers. This nut is secured via a cotter pin.
See pic 1 below and let me know if that is what you are dealing with.
See pic below.
Apr 20, 2023 at 1:30 PM
