I need to change the bank 1 sensor 1 oxygen sensor can you help me?
19,587 MILES • 6 CYL • 2WD • AUTOMATIC
TRAVIS12
Can you help me change the oxygen sensor out please?
Feb 5, 2018 at 4:42 AM
I am attaching the guides below that will help with step by step instructions that will help with this. Also, there is a guide on testing o2 sensors in case you need that as well.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Below is the process from the manual on the o2 sensor replacement process.
Please run through this material and let us know if you have other questions. Thanks
Jun 11, 2021 at 6:26 AM
