Thanks Ken. Will take your advice. Let you know asap. Dodgeman58
Oct 31, 2018 at 1:05 PM
✓Experienced Mechanic
Please do :)
Nov 1, 2018 at 5:58 AM
DODGEMAN58
MEMBER
Ken. I changed plugs and wires. Was not the solution. What do you think about the vehicle speed sensor casing the problem?
Dec 20, 2018 at 5:43 PM
It would through a code if the sensor was causing problems. It sounds like the MAP or clogged fuel filter. If the MAP becomes weak it will give a false reading to the computer without setting a code. Here are the locations for both below with a guide to walk you through the filter change:
Images (Click to enlarge)
Dec 22, 2018 at 4:11 AM
DODGEMAN58
MEMBER
Thanks Ken. Will change both and let you know.
Dec 22, 2018 at 11:27 AM
Dec 24, 2018 at 3:31 AM
DODGEMAN58
MEMBER
Ken. I changed the fuel filter and MAP sensor. Still the same. The problem is when going down hill the car is bucking, no load on the motor. What mechanism slows the car down when on cruise control going down hill? done does not increase. Does the transmission brake? That is what the symptom feels like. Thanks
Jan 15, 2019 at 11:38 AM
Yes, the transmission does hold the engine to the car when decelerating. Have you serviced the transmission recently? If not here is a guide to help walk you through the steps:
