Idles fine but when put into gear it will not move
135,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
ALOKOA530
My van's idle is fine and I rev it up fine, but when I put it in gear it engages but it wont move. I tried stepping on the gas but it barely moved. It acts like it is lacking power. What would be the problem?
Nov 6, 2016 at 8:26 AM
KOOLCADDY6
  • 60 POSTS
You might have a transmission issue. If you can try to see if any transmission codes are present.
Nov 6, 2016 at 9:38 AM
ALOKOA530
Alright, I will do that and I will let you know. thank you.
Nov 6, 2016 at 10:33 AM
  • 55,732 POSTS
The transmission is in two gears at once, Cycle the ignition key five times on and off, this should reset the transmission. If it happens again the transmission is having problems and will need to be rebuilt.
Let me know what happens please, Ken
Nov 7, 2016 at 3:06 AM
KOOLCADDY6
  • 60 POSTS
If the trans is stuck in 2nd gear it is in limp mode and if it is the intermittent concern so I clean the key will set it back to normal. Yes it could have an internal trans issue, it also could be from a sensor or wiring issue
Nov 7, 2016 at 4:55 AM
