Not starting/engine
58,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
MSQUITA199307
I've been having a few problems with my truck. My heater hose keeps breaking at the connector. I got that fixed and it keeps breaking. Now my truck is not starting before it went out it was a lot of white smoke coming out of my tailpipe as well as the back of my engine and I'm smelling gas I went to AutoZone to get a code read and it stated that i have a fuel injector problem and a intake manifold gasket problem. The car cranks but it doesn't start now my engine light was previously blinking also. my temp gauge is not working sometimes it works and most of the time it doesn't. it overheats sometimes also.there was brown liquid stuff on the outside of my oil cap in the front of my engine when it went out and there is oily all on the back of the engine hoses. there is coolant coming out of the side of the engine also . please someone help me and tell me if it could be saved or should i just toss it . please give an estimate of price it will cost to fix please help. thanks
May 25, 2019 at 11:24 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, white smoke from the exhaust usually indicates a blown head gasket. Take a look through this link. It explains how to check and what you will see.
https://www.2carpros.com/articles/excessive-smoke-coming-from-the-exhaust-pipe
Now, if you see coolant leaking from the side of the engine block, either the expansion plug in the block has failed and is leaking, or the head gasket is leaking.
Look through the links I attached. Let me know what you find and if anything in them mirrors what you experienced.
May 25, 2019 at 11:59 AM
