Not starting after replacing cylinder head assembly
76,000 MILES • 2.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
RONALDDESERVA
When I stop the engine of my vehicle listed above due to overhaul cylinder head.
Then after re assemble of cylinder head and try to start but will not start even a small sign of engine run not yet. Thank you for your advice.
Question, why engine did not start after overhauling? I buy new battery. Also new MAF installed we check all electric connections.
Is there any other problem to my car?
Is my car possible to start again?
How can I get help through your site?
Do you have a crew for home service?
Jun 8, 2018 at 10:03 AM
  • 110,248 POSTS
I am not familiar with this vehicle, but after doing research, I found it is based on a Ford Ranger. With that being said, I will provide the engine information for the ranger, which should be the same.
First, please understand there could be many causes for a no start. Here is a link I need you to review. It discuss many reasons for a no start. Hopefully, you will see the problem.
Next, since you had the cylinder head off,. the engine needed to be re-timed. I do not have information for a 2.5L engine. Is there a chance you meant 2.3L?
Finally, I need you to complete a compression test on the engine. This will tell me if the overhaul was successful, if timing is wrong.
Here are directions for this:
I hope this helps. Let me know what you find or if you have other questions.
Jun 9, 2018 at 1:27 PM
