not the right plugs and it stopped running?
180,900 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TOM SMITH2
  • 5 POSTS
I changed plugs and they were not the right plugs and it stopped running, I saw plug where shorter than the ones that came out. I put the proper plugs back in and it will not start. I replaced crank sensor, module and coil pack, still no start. What could it be? I checked timing chain and it has no slack.
Jun 25, 2018 at 3:41 AM
Good morning.
Do you have spark when cranking?
Can you hear the fuel pump run with the key on?
Jun 16, 2021 at 8:30 AM
TOM SMITH2
  • 5 POSTS
Yes, it was the MAF shorted I got a new one it starter right up thank you.
