Not starting
2002 OLDSMOBILE BRAVADA
200,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
JESSICAWOOD365
  • 5 POSTS
Left my driveway drive down the road about thirty seconds worth of drive time and truck shut off and won't turn over or start.
Mar 20, 2019 at 9:50 PM
Good morning,
Does the engine crank over?
Did you check the battery?
Mar 20, 2019 at 9:58 PM
JESSICAWOOD365
  • 5 POSTS
No, it does not crank over, but I have dash lights the door open chime dings. but it will not crank or start.
Mar 21, 2019 at 4:54 AM
Okay, let's start with the battery. What is the battery voltage?
Mar 21, 2019 at 4:56 AM
JESSICAWOOD365
  • 5 POSTS
Checked the battery it's good.
Again, what is the battery voltage? I need information to help you. Telling me it is good tells me nothing. Please give me the voltage.
Mar 21, 2019 at 8:21 AM
JESSICAWOOD365
  • 5 POSTS
12
Mar 21, 2019 at 8:03 PM
If the voltage is 12 volts, the battery is dead. It needs to be 12.4 to 12.6 volts.
Charge the battery as a start.
Mar 21, 2019 at 9:49 PM
JESSICAWOOD365
  • 5 POSTS
I did as you said and it didn't work.
Mar 21, 2019 at 10:54 PM
What is the voltage at the battery now?
Mar 21, 2019 at 11:05 PM
