Battery is fully charged and I replaced started. The starter gear comes out and lines up with the flywheel, but it will not turn over.
Oct 2, 2016 at 11:39 AM
SATURNTECH9
✓Experienced Mechanic
Have you checked to see if the engine turns over by hand?
Oct 2, 2016 at 1:40 PM
GREG HEADINGS
MEMBER
It was run before it stopped on a friend of mine while they were sitting at burger king.
Oct 2, 2016 at 2:11 PM
GREG HEADINGS
MEMBER
I have tested the battery and the old starter. Autozone they said the battery is fine, but starter was bad.
Oct 2, 2016 at 2:13 PM
SATURNTECH9
So the engine just died while it was running? Also does the starter make a solid noise when trying to started it? Like the starter is coming out with a lot of force?
