The starter gear comes out and lines up with the flywheel but it will not turn over
24,000 MILES • 2.3L • 6 CYL • AWD • AUTOMATIC
GREG HEADINGS
Battery is fully charged and I replaced started. The starter gear comes out and lines up with the flywheel, but it will not turn over.
Oct 2, 2016 at 11:39 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked to see if the engine turns over by hand?
Oct 2, 2016 at 1:40 PM
GREG HEADINGS
It was run before it stopped on a friend of mine while they were sitting at burger king.
Oct 2, 2016 at 2:11 PM
GREG HEADINGS
I have tested the battery and the old starter. Autozone they said the battery is fine, but starter was bad.
Oct 2, 2016 at 2:13 PM
SATURNTECH9
  • 30,869 POSTS
So the engine just died while it was running? Also does the starter make a solid noise when trying to started it? Like the starter is coming out with a lot of force?
Oct 2, 2016 at 2:18 PM
