not starting
127,000 MILES
SASSY2007
It sputtered then just quit running battery is good all fuses good replace feul pump cause it was not coming on when u turned key its turning over but not starting and has no fireing to plugs
Apr 11, 2013 at 7:30 AM
check compression for possible failed timing belt
make sure harness to cam and crank sensor is not frayed
Apr 11, 2013 at 8:35 AM
