Engine shut off while driving will not start
100,000 MILES • 1.9L • 4 CYL • TURBO • 2WD • MANUAL
JOHANN NAUDE
  • 10 POSTS
Van just quit running while driving. Injectors not firing.replaced cam sensor, crank sensor and fuel pressure solenoid. Checked timing twice no problem there.I do have 5 volt and 12 volt on cam sensor. 5 volt on fuel pressure sensor on rail but no voltage on signal wire when cranking.Any thoughts on this?
Feb 17, 2020 at 3:06 AM
  • 110,248 POSTS
This vehicle is not offered in the US, but I will try to help. Interestingly, you have power to where it is needed. Does the vehicle start right back up after it stalls? Do you have scanner that can identify freeze frame data?
Feb 17, 2020 at 4:56 AM
JOHANN NAUDE
  • 10 POSTS
Hi there, no we had to send recovery vehicle and yes i do but doesn't work on freeze frame unless vehicle is running.
Feb 17, 2020 at 11:44 AM
  • 110,248 POSTS
Do me a favor, plug in the scanner and see if there is an RPM signal when you crank the engine. If there isn't, recheck the crank sensor connection and wiring.
Feb 17, 2020 at 12:12 PM
JOHANN NAUDE
  • 10 POSTS
Thanks, I will try that.
Feb 17, 2020 at 12:54 PM
  • 110,248 POSTS
You are very welcome. Let me know what you find. Again, if there is no RPM signal, the first suspect is the crankshaft position sensor.
Feb 18, 2020 at 9:21 AM
JOHANN NAUDE
  • 10 POSTS
Sorry guys had to do another emergency.There a hint of a change in rpm not much.Will change speed sensor (crank sensor) and wiring today. will you know by this afternoon.
Feb 18, 2020 at 1:03 PM
  • 110,248 POSTS
Not problem at all. Let me know when you get it done and if it helped.
Feb 19, 2020 at 11:23 AM
JOHANN NAUDE
  • 10 POSTS
Hi Joe,
Thanks, broken ground wire. Purring like a kitten.
Feb 19, 2020 at 1:03 PM
  • 110,248 POSTS
You are very welcome and I'm glad to hear it was a simple fix. Please feel free to come back anytime you have questions.
Feb 19, 2020 at 1:08 PM
