Not starting changed the battery, fuses, and the fuel pump?
108,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
MIKESMITH845221
I've changed the battery, fuses, and the fuel pump. Had a mechanic look at it to verify that power is not going to the fuel pump. Where is the fuel relay?
Feb 21, 2020 at 7:25 AM
  • 110,248 POSTS
The fuel pump relay is integral at the integrated power module, a part of the printed circuit board (PCB). It is not something that is serviceable.
The next thing I would suggest is to confirm the auto shut down (ASD) fuse is good. It is located in the power distribution box under the hood. See pic 1
Also, if you look at pic 2, it shows you the pump connection for the ASD. If it fails, you lose the fuel pump.
Let me know what you find.
Aug 30, 2020 at 4:28 AM
