Not starting
184,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
STACI2527
It's turning over but its not getting gas and the fuel pump is coming on
Dec 21, 2015 at 5:32 AM
JDL
  • 16,098 POSTS
With engine cranking, I want to check spark at the spark plugs, where applicable. Use a gage and check proper fuel pressure, engine cranking and check fuel injector pulse.
If you missing all three, check for an rpm signal, should come from crank sensor. Don't replace anything unless your testing points in that direction.
Also, check your security/theft system.
The fuel pressure you saw, might have come from the initial prime, that doesn't need an rpm signal.
Dec 29, 2020 at 4:13 AM
