not starting after replacing the starter?
1999 CHEVROLET LUMINA
98,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
FRANK POSTON
put a new starter and when i turn the key on i only get a clicking sound from the starter. The cigarette lighter is not working, electric door locks not working, hazard lights are not working, and the alarm will not lock and unlock the doors. i have to use the key to open the door. can you help me with this?
Jul 27, 2024 at 5:47 AM
  • 110,240 POSTS
The first thing I need you to check is if the battery terminals are both clean and tight. If they are, confirm the negative cable from the battery to the engine block is also in good condition.
Let me know what you find and if you have confirmed the battery is fully charged.
Jul 28, 2024 at 1:03 PM
