Not starting
150,000 MILES • 3.0L • V6 • FWD • MANUAL
JUSTIN ASHMORE
Recently car shut off while driving and has not started since. It made a gasp for air noise three times and would almost shut off. So I replaced the fuel pump and got codes 556 and 557. What should I do before replacing the CCRM since that is where the fuel relay is?
Jun 22, 2017 at 1:53 PM
  • 55,658 POSTS
I would make sure the fuel pump operation is the problem. Use a test light and see if the fuel pump is getting power.
Here is a guide that should help you and a wiring diagram (below)
Here are some more guide that will help.
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
Jun 26, 2017 at 4:07 AM
