Not starting
95,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
SAMADDAH
The vehicle showed check light. Started stalling when going up hill. Cranked several times before starting. Then finally not starting at all.
Engine code P0335. Replaced crankshaft sensor, new pump, injectors, spark plugs but still not starting.
Jun 5, 2017 at 12:23 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge it may be low. auto parts rent the gauge and you may need an adapter to check it. See link. Also, check security reset see link as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jun 5, 2017 at 1:04 AM
