Not starting
169,438 MILES • 1.4L • 4 CYL • 2WD • MANUAL
MGT AUTOMOTIVE
The car hasn't been operating for the past ten years. I tried to start it, but it didn't start. Then I did the service, replaced the fuel pump, and cleaned the crankshaft position sensor and the fly wheel. The immobilizer is functioning well, and I even bypassed the ECU ground cable pin 39 but it doesn't want to start. What could be the problem?
Mar 7, 2022 at 10:00 PM
BORIS K
  • 836 POSTS
For a petrol engine to start we require three things,
Fuel
Spark
Compression
Ensure that you have clean fuel in the tank and in the lines, check the fuel pressure.
Fuel pressure should be around 4 bar
Ensure that the fuel injectors are spraying, not stuck or not getting impulse.
Impulse testing can be done by using a Noid light.
How to use a Noid light.
https://youtu.be/_teotIHmz7U
Check that you have spark when cranking the engine
Carry out a compression test, you should see 10-12 bar on each cylinder.
How to carry out a compression test.
Compression low reasons.
https://www.2carpros.com/articles/the-reasons-for-low-compression
https://www.2carpros.com/articles/symptoms-of-low-compression
Please let us know how you get along.
Cheers, Boris
Mar 8, 2022 at 1:23 AM
