not starting
198,000 MILES
TOMPOH
Stalled. Cranks over. Does not start. With key on, check engine light flashes rapidly. Four times faster than a misfire code. Hooked up scanner to the OBD and it does not read anything. Assuming the PCM was bad, I replaced it with the proper one and supposedly programmed with my VIN before installed and still nothing. Any ideas?
Thanks, Tom
Apr 15, 2017 at 1:34 AM
  • 55,748 POSTS
It sounds like the engine could have jumped time, lets start with a compression test to see where we stand.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 17, 2017 at 9:10 AM
