start and run for a split second?
211,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
CARDINALS45
So, it won’t start, sometimes it’ll start and run for a split second. I changed the TIPM. It has fuel pressure. It cranks over fine. Could it be spark plugs? I had a code that says low system voltage. But that’s all.
Jan 4, 2025 at 6:57 AM
  • 55,765 POSTS
Yes, it could be the spark plugs if they are carbon fouled. I would try starting fluid to see if that changes anything. I would check for spark as well because I have seen the crankshaft sensor go out and cause this issue, also can I ask if the security light is flashing while you crank it over?
Here is a video to help you:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
How does the engine sound while cranking normally? If you upload a short video I can tell if the engine is hurt or not. Please go over this guide and get back to us.
Jan 5, 2025 at 6:59 AM
