Not starting
85,000 MILES • 1.6L • MANUAL
ZPATTERSON
Over the last couple of years, I've had trouble with the car starting.
If it was left for a week or more, it wouldn't start when I got back to it and because I travel a number of times a year and need to leave it at the airport, I bought a Buture jump starter which works perfectly.
Lately the problem has gotten worse and if I didn't use it over the weekend, by Monday it wouldn't start. It now needs to be jump started or charged every day!
When I go out to the car in the morning, it needs to be jump started so I can get to work and by the evening, it needs doing again.
I also have a battery charger and when I've fully charged the car, it starts fine but after a day or two, it won't start again.
I went and had the battery checked and it came back as good. I also took off the negative cable, fully charged the car, put the cable back on and it started. I then took the negative cable back off and left it overnight. The next day I put the cable back on and it started. I was told this means the battery is okay and it could be the alternator. I didn't drive the car that day and the next morning it wouldn't start again.
I had a new battery fitted about 3 years ago and a part used alternator fitted about 2 years ago.
Any ideas on what it could be, or my next step would be much appreciated!
Jan 18, 2022 at 5:31 PM
Good morning,
The battery can pass a load test but still drain itself over a short term from sulfation.
I attached a guide for you to test for a parasitic draw.
https://www.2carpros.com/articles/car-battery-dead-overnight
There should be no more than 50 to 75 milliamps drawn on the battery with everything off.
I would also check the charging system as well.
Jan 18, 2022 at 8:07 PM
