not starting
70,000 MILES • 2.0L • 4 CYL • AUTOMATIC
HENTAIL
I replace my head which was new came with valves ,camshaft and valves already install along with new head gasket. i torque the head bolts in sequence as manufracturer request check for oil and coolant leaks none. The coil pack, spark plug wires and plugs are new, the fuel pump is new. The fuel filter is new, the starter is new, the camshaft and crankshaft position sensor are new, the ignition switch is new and the battery is new. The car is cranking, but not starting. The lights on the instrument panel are coming on with engine check light.
May 3, 2016 at 2:36 PM
  • 31,937 POSTS
Something may be unplugged, run a scan to see what has set the check light, re check for spark, injection pulse and fuel pressure as well.
Apr 2, 2018 at 1:33 PM
RENEE L
  • 1,260 POSTS
Here is a link to an article that features written instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one from Amazon.com. Once you have the codes please get back to us so we can further assist you. Thank you for visiting 2CarPros.
https://youtu.be/YV3TRZwer8k
