Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Drivetrain
Transmission
Symptoms
Not Shifting
Not shifting down
2000 CHEVROLET S-10
215,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
RJRT
MEMBER
After the truck is warmed up when you get down to about 20 mph the truck doesn’t want to shift down to first on its own.
May 21, 2020 at 4:38 AM
Experienced Mechanic
Good afternoon,
Does the transmission up-shift okay?
This sounds like a valve body issue.
when was the last time you changed the fluid and filter?
Is the check engine light on?
Image (Click to enlarge)
May 21, 2020 at 5:09 AM
RJRT
MEMBER
Yes, it shift up fine. it’s just 0 to 20 that it has trouble.
May 21, 2020 at 5:25 AM
RJRT
MEMBER
I am not sure about when the filter was changed, but it had new fluid a couple months ago.
May 21, 2020 at 5:29 AM
Do you mean from 20 to 0?
Did you change the fluid and filter?
May 21, 2020 at 5:30 AM
I would still drop the pan and change the fluid and filter.
May 21, 2020 at 5:32 AM
RJRT
MEMBER
Yes, I meant 20 to 0.
May 21, 2020 at 8:40 AM
Okay, I would start with changing the fluid and the filter. Look for any debris in the pan or on the magnet on the bottom of the pan.
If that does not work, most likely the valve body will have to come down and gone through.
May 21, 2020 at 8:42 AM
RJRT
MEMBER
Okay, thank you. I will start with that.
May 21, 2020 at 9:01 AM
You are welcome.
Always glad to help.
May 21, 2020 at 9:06 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
