not shifting
122,432 MILES • MANUAL
JASON CAMERON
replaced the clutch master cylinder and slave cylinder, but cannot shift.
Mar 1, 2017 at 1:39 AM
HMAC300
  • 48,601 POSTS
if it will shift while engine is off then it is probably a clutch problem or air in system. also, check cables or linkage for proper adjustment or stretched cables. if it will not shift with engine off then it is either a transmission problem like a synchro/shift fork etc assuming linkage is okay.
Mar 2, 2017 at 4:20 AM
