All of a sudden the engine bogged down and traction control and stabilitrak lights came on
105,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
SHARONDAILEY7976
It was running fine and then all of a sudden the engine bogged down and traction control and stabilitrak lights came on. now it barely has enough power to pull its self. I put a new MAF sensor on it and clean the throttle body.
Mar 28, 2019 at 10:21 PM
Good morning,
Is the check engine light on? If it is, do you know the code?
Have you checked the fuel pressure? Low fuel pressure can cause this.
Do you know the code for the ABS system?
Mar 28, 2019 at 10:30 PM
SHARONDAILEY7976
No check engine lights are on now. I reset them.
Mar 28, 2019 at 10:42 PM
SHARONDAILEY7976
Still not running right.
Mar 28, 2019 at 10:43 PM
SHARONDAILEY7976
The only cods it was throwing were misfire 300 codes.
Mar 28, 2019 at 10:44 PM
Okay, clearing does nothing as the issue is still present and needs to be addressed.
I would start by checking the fuel pressure as I stated. Low fuel pressure will set this code due to not enough fuel to the rail.
Mar 28, 2019 at 10:58 PM
