Not starting/running
ZAC STEVEN'S
  • 1988 CHEVROLET CORSICA
  • 0.5L
  • 4 CYL
  • 120,000 MILES
So I replaced the idler pulley in my car which was making the belt lose. So I fixed it and thought that's why my car wasn't running and yes it was a problem but now it wont start. It will turn over and give gas and a spark. It builds pressure but it will not start and it revs like it wants to.
Thursday, January 16th, 2020 AT 6:24 PM
SCGRANTURISMO
  • 4,897 POSTS
An engine only needs three things and then it pretty much has to start. In no particular order they are fuel, spark [delivered at the proper time], and compression. If you have verified that there is fuel pressure at the fuel rail and the fuel injectors are firing, and there is spark at the spark plugs, then the only thing that would stop the engine from starting would be the engine's compression, or lack there of. In the diagrams down below I have included a link to a guide describing how to do a compression test.
Please go through this guide and get back to us with the results. We can go from there.
Thanks,
Alex
2CarPros
Thursday, January 16th, 2020 AT 8:50 PM
