Just to clarify, the shift lever is stuck in park?
This could be an issue with the shift interlock. It is what allows you to shift out of park after the depress the brake pedal.
The shift interlock actuator is located under the shift lever (see diagram).
Sometimes the connectors can come loose of the actuator and can cause issues as well as it can be a faulty actuator as well.
Do you hear any clicking noise when you apply the brake to shift out of park?
https://www.youtube.com/c/2carpros/featured
Please let me know little bit more details.
Images (Click to enlarge)
Sep 4, 2021 at 2:18 PM
