NOT RUNNING
136,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
DONGOLAMAN
  • 6 POSTS
OIL LITE CAME ON I PULL OVER AND CHECKED OIL NO OIL SO I PUT 3QUARTS IN READING WAS FINE,SO I DROVE OFF SOME 20MILES WITH LITE STILL FLASHING MADE IT FINE,STARTED BACK ON HOME GOT ABOUT 25MILES FROM HOME ,OIL LITE STILL FLASHING CAR STOPS ALL THE SUDDEN WITH THE ANTI-SLIP LITE ON.
Apr 21, 2016 at 4:59 AM
SATURNTECH9
  • 30,868 POSTS
You post a question and when someone is available and reads it answers it.We don't have a instant messaging system to answer questions on here.So if you try to start the engine what happens?If you got low enough on oil or lost oil pressure you could have a seized damaged engine.
Apr 21, 2016 at 5:29 AM
DONGOLAMAN
  • 6 POSTS
THANKS
Apr 21, 2016 at 5:34 AM
DONGOLAMAN
  • 6 POSTS
WHEN I TURN KEY TO ON POSITION LITES COME ON ON THE PANEL AND GO OFF I HEAR FUEL PUMP PUMPING.
Apr 21, 2016 at 5:36 AM
DONGOLAMAN
  • 6 POSTS
COULD IT BE A FUSE?
Apr 21, 2016 at 5:37 AM
SATURNTECH9
  • 30,868 POSTS
So when you turn the key to the start position what happens?is there any clicking sound?I loud clunk like its trying to turn the engine over but can't?I need details I can't see hear etc anything on your car where iam at .
Apr 21, 2016 at 5:49 AM
DONGOLAMAN
  • 6 POSTS
the cam is turning
Apr 21, 2016 at 12:52 PM
SATURNTECH9
  • 30,868 POSTS
So do you have spark ?How is the compression?
Apr 21, 2016 at 1:46 PM
DONGOLAMAN
  • 6 POSTS
WHAT DO U MEAN SPARK?
Apr 21, 2016 at 10:43 PM
  • 55,766 POSTS
Hi Dongolaman,
Here is what he means by spark
Check this guide out:
let us know what you find
Apr 22, 2016 at 12:47 PM
SATURNTECH9
  • 30,868 POSTS
Sorry had a crazy day just saw the reply.Let us know what you found.
Apr 22, 2016 at 1:43 PM
